solardanman
I appreciate the replies. Starting to feel a little better. I have a reply from Howard and he mentioned
"Did you check the real QR code under the stickers?
because the CATL has not released this version to the market yet,
so we put the 280 stickers on it.
You can please test these cells and check the capacity.
Best Regards
Howard"
Here what it shows. Am I reading it correctly. My scanner does not scan this one using the lifepoqr battery reader.
Code Check...
Code: 001-cb-7c000-000bc-an130-4823
Code seems right.
Code length is right.
Manufacturer:
CATL
Product Type:
Battery Cell
Battery Type:
LiFePO4
Nominal Capacity:
Don't Know Yet
Nominal Voltage:
3.2V
Production Date:
22/Oct/2022
Manufacturer Website:
below is an example of the stickers over the original qr code. At lease they are not scratched off
here is the latest reply
The website or App does not have this CATL version data,
and the code defined has been changed as well.
It will be better for you to test these cells,
fully charge/discharge if you want to confirm the real capacity
Best Regards
Howard"
I am testing one now, see you in a week since I only have a 10 amp charger and 20 amp discharge tester.
Best Regards
Howard"
LiFePO4 Cells QR Codes Decoder : GobelPower.com
GobelPower.com : LiFePO4 Cells QR Codes Decoder - China Lithium Battery Distributor and manufacturer, Offers LiFePO4 Battery, 18650 Battery, 12V/24V/48V/72V Rechargable Lithium Battery for Home Solar Energy Storage, Electric Bikes, Scooters, Forklifts, Sweepers, Mowers and Boats.
www.gobelpower.com
Code seems right.
Manufacturer:
CATL
Product Type:
Battery Cell
Battery Type:
LiFePO4
Nominal Capacity:
Don't Know Yet
Nominal Voltage:
3.2V
Production Date:
22/Oct/2022
Best Regards
Howard"
