EG4_Jared
Online Support for EG4 Electronics
More information can be found here: https://eg4electronics.com/categories/batteries/eg4-wallmount-indoor-280ah-lithium-battery
Depends on each setup. For example I’m putting 4 power pros as a 2x2 setup = = from wall so the side screen and breakers are actually accessible for meConnections on the top and display on the front is much better. Definite improvements.
But with the breaker and power switch still on the side. You can't place them side by side for a clean install.
It would be a lot cleaner, if you could line them up side by side. Put a standard electrical trough across the top of all of them. And put the AIO's on top of the trough.
These are just suggestions for version 3.
That's a very odd setup. But yes, each installation has its individual needs.Depends on each setup. For example I’m putting 4 power pros as a 2x2 setup = = from wall so the side screen and breakers are actually accessible for me
Can it be paralleled with the outdoor version? Connections looks the same, I assume the protocol is the same?
I'm switching sides now to say I wish it was all one side lol. Because I'm picturing these things lined up sideways back to back. I'm extremely space constrained.Connections on the top and display on the front is much better.
Our wirebox is cheaper than standard trough and saves time I thinkConnections on the top and display on the front is much better. Definite improvements.
15.45 kwh. That’s a 8% ah increase, at what price tho.I wish they would use the 304Ah cells. Getting over 15kWh just seems better.
Personally I don't like the wire boxes. They're gaudy and look out of place.Our wirebox is cheaper than standard trough and saves time I think
I would think that 4" would be enough. If you remove the breaker cover.How close to each other can you install them, to be able to reach in and access the on/off and breaker on the side? The 12" requirement of the older model was pushing me toward server rack style batteries, but if only 3-4" or so required for these, they would sure be a space saver for our new build.
Anxious to see how the spacing between them comes out with the conduit boxes, I can't tell how much the recommended 12" spacing on the outdoor model is code and how much is reasonable access to the side controls. Will seems to want to put them right up next to each other, but the latches on the conduit boxes will require _some_ minimum spacing.Our wirebox is cheaper than standard trough and saves time I think
The new Ruixu one is 304 or maybe 314Ah cellsI wish they would use the 304Ah cells. Getting over 15kWh just seems better.
