Picked up on Wills recommendation video a TimeUSB 220ah 12.8v lifepo4 battery The plan is to just replace the house battery with this unit. But, it appears the BMS has a different plan. When I connect it to the existing batteries location, the voltage drops to 0, and you can hear the BMS "click". No output. When disconnected it will show 12.4 again. I tried connecting just a small 300w inverter to it (no load) with just the alligator clips, and it does the same thing, 0v. Unplugged, back to 12.4. plugged the Victron charger in, shows absorbtion mode, at 14.4v, but amps is 0.0? Doesn't sound right...
Thanks for any help...
-Mark
-Mark
