Plenty of information on these forums to get you started learning the new stuff!
So I have asked this in an RV forum and did not get the response I was hoping for. So I thought I would post it here.
I keep hearing that you need to disconnect your panels from your controller if you are going to remove your batteries. I understand that if you do not you will have live wires in the battery bay after you remove them. But I keep seeing the myth that your solar controller will burn up if you do that because it will convert the energy from the solar panels into heat and cook itself. So if you can help me understand something, I would greatly appreciate it.
Myth or Fact: If you do not disable or disconnect the solar panels from the solar controller, you risk burning up your controller if a battery is not also connected to the controller.
I can see the logic in the myth and don't necessarily doubt that this could happen with some controllers.
But, what is the difference in the scenario where your batteries are disconnected and unable to absorb the engery and the batteries being 100% SOC and unable to absorb the energy?
If the controller somehow manages the panel side of the circuit and opens it somehow when the batteries are full, why doesn't it fail the panel circuit open when batteries are not present to protect itself? Or does this already happen in some fashion and the myth remains a myth?
I am hopeful someone can explain the how and why here. I can and will test it sometime myself but am hopeful someone else has done this or has specific knowledge.
My intention when I have the trailer out next is to measure voltage on the controller to negative battery terminal while it is disconnected in the sun and see if voltage is flowing into the batteries when the controller is powered off since I think it is powered from the batteries and not the solar (is this generally true?). That should tell me whether the controller is disconnecting the panels when powered off. I will also pull the controller out and try to measure heat on the unit / heatsink.
For particulars about my setup:
Factory installed Go Power 570w kit with non-bluetooth PWM 30 amp controller and 3x190w panels and 1500w inverter with transfer switch. Everything there is factory and connected to 2x100ah GoPower LFP batteries which are also non-bluetooth. I do have a Victron smartshunt with bluetooth.
If anyone has any input to any of this, or has already done this type of thing, please please let me know .
Thanks all
Thanks for the info RV8R. Just in case it was not clear, my particular use case is a very small (3 panelx190w ea) RV system that was provided OEM. GoPower branded, PWM controller, 2x100ah LFP.
ETA: I also have a Victron SmartShunt that I forgot to mention. 1500w GoPower inverter, 65am WFCO 9865-AD converter. That is about it I think.
I really don't have any issues with my setup right now. Everything is working great with only one exception.
When I have drained my batteries such that I need a full bulk mode cycle (my converter will run up to 4 hours in bulk (14.4v) before falling back to absorption (13.6v) - these are the words they are using. All good so far.
What happens during the day is that the solar interferes with the converter such that the converter exits bulk mode after an hour because it is not detecting sufficient net load and goes into absorption mode prematurely. I have not had time to play with how much of a load I can put on the 12v to offset the solar charging, but I don't think I can get there reasonably, nor do I really want to.
1. If I am going to be on shore power, I don't care and would just live with this as it will be charged by the next day, it will just take longer to get there (yes, 13.6v will charge my LFP to 100% SOC).
2. If I am looking at needing to run my Onan LP 5500 (sorry I did not include that???), I do not want the charge to be in absorption mode any sooner that nit needs to be.= for obvious reasons.
3. If I install a disconnect switch on the OEM solar, I can prevent it from interfering with the detect functions on the converter and it will stay in bulk mode for up to 4 hours before dropping to absorption. 4 hours is the time limit for bulk. If they were really low, I could just power cycle the converter to start charging in bulk mode again.
4. So part of my initial question was going to be whether I should install a disconnect between the PV and SCC, or whether it was sufficient to just install one at the batteries (this will be much easier). But I heard horror stories (myths?) that leaving PV connected to SCC without load could fry SCC, which I didn't want. It seems that is not a problem and my SCC has no autodetect function - so I don't think there is really much (any?) risk either way. And here we are lol.
5. In my last test with the trailer in the storage building I was able to prove out #3 since there was no solar coming in.
This is quite a rabbit hole to go down and I feel like I am learning a lot for such a short time and am reading posts and the stuff others have provided as quickly as I can.
For the schematic, I can put something together but it might take me a bit to get that done. I have to find somewhere to build one (draw.io maybe?).
The manual for my SCC is lacking as is for the rest of theGoPower equipment (the inverter is not AS bad as the others). This kit is really intended for the lowest common denominator. I am posting the product links for those who are curious what I mean here. Each has a documents section on them.Schematic ,,, “Pen & Paper & Photo & Post” ,,, not looking for “Professional Quality here - just a chicken scratch to begin with.
FYI, this is the first post of yours on here where I actually understand your problem & why you are asking questions & that you have an Onan ,,, I feel we are getting somewhere now.
Basically you have parallel chargers operating simultaneously that are not necessarily “playing well with each other” ,,, got it ,,, lets get that sorted out for you
Regarding your solar charger - what does the manual or manufacturer say about disconnecting procedures ??
I typically do not have multiple chargers running simultaneously on my 12vdc systems as I simply don’t need them. But I believe “The Forum” can help sort out your multiple charger issue.
FYI ,,, IIRC “Renogy” has a dual ( alternator / solar ) 50amp & a poor logic IMO of only allowing 25amps each when both are available ,,, & that is in 1 magic box . What that boils down to is only 25amps from the alternator when on crappy solar days & driving.
So I understand you wanting to know how these things work & how to get them to play nice together.
If you get the info from your Solar Charger, you will discover the “right way” to stop that charger. If it is by opening the PV wire circuit get a decent “disconnect”;
PV Disconnect for 600W Array ( 60 V @ 10 A )
For my remote cabin, I am considering a “Combiner Box” or a “Breaker” for the “Primary” function as a PV Array “Disconnect”. Currently I have 6 100W panels 3S2P so roughly 600W ( 60 volts @ 10 amps ). I have a Victron 100 | 50 MPPT I consider the combiner box a choice for future upgrades, but...diysolarforum.com
mppt fuse question
www.promasterforum.com
@datdude ,,, I am bulk posting here for you to attempt a lot of info as I think you are thirsty for it. The following is important IMO in the “Internet DIYer World” ,,, kinda goes hand in hand with “Trust but Verify” ,,, Anyway in the DIYer Van Design / Build it is like the Wild West of “Blind leading Blind” with surface scratched just learned info & “Parroting” without a very deep knowledge base ,,, Just do this - I did ;
So “Even” with a properly rated “Disconnect” ,,, IMO, it would be “Best Practice” to always use that disconnect after turning the “load” off ,,, thus only using the ability of the “disconnect” under load in an emergency situation. I suppose some could fault me with that perspective ,,, but I would need to know why.
I don’t understand the video. He intentionally shorted the breakers.
Was it to prove the DC arc would overpower the circuit breaker?
Or/and the CB is not able to properly open under overload conditions and provide needed protection?
I recently added a similar CB to route my RV’s 400 watts of panels through to my SCC.
