Now what is the "correct" way to add more charging power to my system? With two Deye12Ks I can charge only ~26kW (2x240A) at the moment while I have ~100kWh of batt capacity plus I can use two different batt chemistries. Also my "Little blue" genny should be on it's sweet spot around 30-40kW.
Chargeverter(s)? / another Deye?
With about 3,5 Chargeverters I could get another Deye12K. That would mean 17,5kW vs 13kW additional charging capacity, but with Deye I could also get more MPPTs and raise my surge capability from 48kW to 72kW plus have three different battery banks to charge. I think that's a win for another Deye, but it is possible there can be compatibility problems with three Deyes connected parallel without comm cable between them. I already know how good my two Deyes are working together without comms so I'm willing to take my chances with it. The big question is how to charge with my old 1967 50kVA diesel generator? Is the power pure enough, and if not, can Deye purify it (like Chargeverter(s) can?)? From what I've read before only one Deye can be used with generator when they are connected with comms and thus have a common battery bank to charge. That means only ~12kW(?) battery charge from generator is possible no matter how many Deyes there are. But if I don't use comms like my current setup with two Deyes, I could gen charge each with that same power? So with three Deyes I could charge 3x12Kw=36kW using "Little blue"???
Thoughts? Anyone?
