Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,789
The diesel generators on DC Solar trailers were 7kW or 11kW. More than most need for charging.
How well would it work if governor was turned down to 1800 RPM, delivering 30 Hz and maybe half voltage?
Feed that through Chargeverter, which is a wide voltage range switch mode power supply - does it work outside normal frequency range? (Chargeverter derates at reduced voltage, might need two.)
That would run quieter, probably give considerably more hours life (whether or not more kWh life.)
Of course there are Lister diesel generators. Apparently Chinese knock-offs, too. "Liseroid"
