Not very efficient I assume to run it at 50% load?I've used a Champion 2500w dual fuel - https://www.championpowerequipment.com/product/100899-2500-watt-dual-fuel-inverter/ - and it runs OK and is pretty quiet. It can do 1200w continuous.
Not sure what you mean. To me, efficiency is how may watts per gallon of fuel - and at 50% it's similar efficiency to 100% load - just takes twice as long to burn the gallon. They say 80% is an optimal load for many generators but I don't have any data on either of the ones I've mentioned.Not very efficient I assume to run it at 50% load?
So the key issue is to be able to have a charger (or bank of chargers) so you can vary the charging rate to get in that 'most efficient' load range for you're generator. This is where the EG4 Chargverter 5000 is so sweet - it let's you select the charging amps so you can adjust the load on the generator. This can also be done by having several chargers on a power strip with switches - say you had 4 x 10a chargers - then you could select 10a, 20a, 30a, etc until you create an efficient load on the generator.That's right. How many watts per gallon. From what I've read/seen, at 50% load, its going to cost an extra 20% in fuel to get the same amount of watts as if running @ 80%.
Do they have a 1200 watt model?Honda generators are known for reliability and service after the sale. I have a 20 year old Honda EM5000S that's still running strong although I don't use it as frequently now. Champion also gets good marks here for support after the sale.
Generator longevity is better at 80% than 100%. In fact, a lot of cheap generators cannot run at 100% for extended periods of time. In addition, power output is more stable at 50-80% where the generator has reserve power to maintain output. Finally, you want reserve capacity to handle changes in load.That's right. How many watts per gallon. From what I've read/seen, at 50% load, its going to cost an extra 20% in fuel to get the same amount of watts as if running @ 80%.
Tell me more about your setup. I’m trying tofigure out what you have.So the key issue is to be able to have a charger (or bank of chargers) so you can vary the charging rate to get in that 'most efficient' load range for you're generator. This is where the EG4 Chargverter 5000 is so sweet - it let's you select the charging amps so you can adjust the load on the generator. This can also be done by having several chargers on a power strip with switches - say you had 4 x 10a chargers - then you could select 10a, 20a, 30a, etc until you create an efficient load on the generator.
For my home powerwall, I have both setups and like the Chargeverter best.
I'm shooting for 1200 peak, 1000 running.Hard to hit exactly 1500 watts.
Its a 1200 watt propane gen? How many hours do you have on it?I like my Pulsar so far but I think it is disposable.
I have an EG4 Chargerverter -> the battery buss which is 90% efficient and to get the full 100a you need to provide 240v - so it's wired for 240v from my large generator.Tell me more about your setup. I’m trying tofigure out what you have.
I think it's like 1600w on propane and 2000 on gas, dual fuel.Its a 1200 watt propane gen? How many hours do you have on it?
