The 60' 160, 80, 40m vertical on palm has raised (fence high) trapped coaxial radials. There is a tuner box with fixed L's and C's at the base. I also have a TR switched 160, 80, 40 trapped dipole on fence line for receive noise reduction....all on a small City. The homemade diy 35' telescoping mast with the beams on it took a while to build.....6' deep X 2' X 2' hole for mast base plate mount was dug by hand. Concrete for base was strength tested to see if it met mechanical design doc I needed for permit. All the bronzr flat bearings and pully assembly was made in my small machine shop....or welded.
