sparrs
Setting up a solar system from scratch, I've found some great, concise information on here and realized the time has come to quit lurking and post for some specific answers.
Batteries:
Looks like a Gen2 Tesla 24v battery pack offers the best value used from a low mileage vehicle. Not sure if I'll be pulling the existing circuit boards off and wiring direct to my charging arrangement? Link here:
Cables: Sized to current. No problem if I'm pulling four pairs of 2AWG.
Panels: Qcells Q.peak Duo ML-G9+ 375-395 Watt, 10 available. Not interested in undersizing any part of this. 42V open circuit, 35V MPP.
System voltage: It seems 24v is adequate, but 48v drops the wire size needed and overall cost into conductors. 24V components seem more common, given that 48v is younger. Open to thoughts, I could go either way. I'm thinking 4 or 5 parallel, 2 series on the panels if 48 volts. Any special considerations for the series panel arrangement, or wire and go?
Charging: This is where it gets complicated. MPPT charge controllers are an apparent choice, with Victron and some other brands mentioned.
If I can do it all with direct feeds from the panels into an inverter/charger, this would be ideal for seamless voltage control, all handled by one unit and power sharing on demand from panels and batteries. I saw the Outback Radian charger/inverter series mentioned, curious if this fits the bill or if there's a better manufacturer for a reasonable price.
Another source mentioned a charge controller still being needed in addition to an inverter/charger - why would both be needed? It's not like the charge controller can step up the voltage. Anything I'm missing, good manufacturer recommendations and some clarity on this design would be welcome.
Batteries:
TESTED w WARRANTY 5.3 kWh Tesla Model S 85 90 EV Battery Module 24V Gen 2 Cells | eBay
They are backward compatible and will fit 2012 to 2020 Tesla Model S and X with proper knowledge. Beware of Gen 1 modules as they are aging out at 10 to 12 years of age and failing. Total energy storage is 5.3 kWh.
www.ebay.com
