dborn
Hi all,
I have a basic understanding of electricity (volts, watts amps, etc) but I need your help in solving an issue I don't understand.
I bought a kit from evextend.com that includes a split-phase 24v inverter in the basement with 6 x 12v 100Ah AGM (2S3P) batteries. It also comes with a specially modified 24v battery charger, 30A detuned to 26A to draw up to 1000W 120vac from a 12vdc to 120vac 1500W inverter connected to my EV (Chevy Bolt) in the garage. This charger is used to top up the downstairs batteries while the big inverter runs the house. I have built a 25' 12ga extension cord that i plug into the car inverter, connected to a round 120v generator plug that is connected to a wall socket and 20' lumex 12ga solid wire that runs through the walls down to where i connect to the 26A charger. When I start up the car inverter, it runs for about 5 minutes before tripping its short-circuit protection. If I replace this cable with a 100' 14ga garden extension, it runs fine for hours.
I tested my heavy extension connected to the house wire going to the basement with a heavier load (hair dryer on MAX) for 10+ minutes, connected to a wall outlet in the garage and all is good, so there is no short.
I'm at a loss to explain what is going on and more importantly, how can I fix this without having to run a stupid extension cord from the garage to the basement.
Thanks for any insight and sorry for the long winded explanation, just trying to paint a complete picture.
