Respectfully, Yikes! I think you are saying something that has no basis in reality.
Offshore manufacturing plants can be faulted with many things, but to categorize them as "using whatever random FETS that they can get their hands on ..." is just wrong. It would cost manufacturing more to have "random parts" as their discount comes from using the same part multiple times.
Additionally, if FETs are used in parallel and they are all the same part number, there is no benefit of "closely matching" them.
They are an on/off switch with a documented resistance (loss) when on.
Closely matching transistors harkins back to the dark ages of bipolar transistors.
John
I think perhaps a bit of hyperbole can be excused in the point
@gnubie was making; "random mismatched parts" doesn't
necessarily mean that random parts will be in a single device, because indeed, most parts purchased by a manufacturer will be in million-count packaging... but a very important consideration here, particularly when discussing device reliability, is matching components across devices of the same make/model. Yes, perhaps all the FETs inside device A match, but if device B, of the same make and model as device A, does not have
the same FETs, then the reliability -not to mention the real-world tech specs- of both devices become highly questionable. A prime example of this is Renogy... Renogy is not a manufacturer, it's a branding company that buys up random warehouse overstock and discontinued devices from solar panels to controllers to inverters to batteries, and slaps its name on them and sells them. And hey,
some of those components it purchased and rebranded are great.... and some are utter crap. The problem is, there's no way to tell which is which until something fails, because there's no guarantee of -or even convincing attempt at-
consistency.
You can see an example of this in Renogy's battery specs and charge recommendations... try to get a straight answer out of them from one day to the next of what their max current rating is, or proper charging voltage/current, and you'll never be able to... because they themselves have no idea what the specs are because they didn't design or manufacture the cells or, more importantly, the BMS.
For our customers, for whom proper operation of their equipment can literally be a mater of life or death, consistency and reliability is absolutely critical, and that's why we would never distribute Renogy, or Xantrex, or Aims, or any of the truly off-brand components like the knockoff Blue Sea breakers that I see being touted everywhere because
oh, they're half the cost!! Yes... but you have no idea how -or
if- it will perform, and considering that a malfunctioning component can easily cause a fire, or electrocution, or strand you in the middle of nowhere... you have to ask yourself whether that little bit of money you saved was
really worth the ever-present doubt that you now live with.
